08-16-2022, 07:29 AM
I should have posted an introduction in the new members area but I recognize a lot of you from Astromech.net. I have been at a point in my R2-GT build (Full Aluminum) where every new part is getting expensive and I have a lot of downtime between parts purchases. So I started up a Braided Foot Hose Parts Run to keep me building and its also in downtime right now waiting on material to arrive. Well my 3D printer has been sitting quiet for far too long and then I come across a Facebook post.
1st off... Devinrayolsen is a bad influence . I saw a post on the R2 builders Facebook page of a 3D printed Fusion Generator. So I went down the rabbit hole. In less than a day, my printer was already running. So on day 5 of joining RebelDroids.net I am making my first post and it is a build log. I like to document parts and pieces and take pictures like crazy, so hopefully my log will help me understand what I am doing, document my errors, and maybe in that process help other builders.
So the next order of business is to thank SavageCreature, Kresty and Devinrayolsen for their work on this. Any one else I missed, THANK YOU TOO!
Lets start this build off with the reference photo!
.... and a box of parts.
Printing started off with the bottom pieces - A (4), the Vertical Supports - B (8), the first set of vertical rings - C (4), and the first set of horizontal rings - D (4).
I attached all 4 bottom pieces (A) together and then added the Vertical supports (B). The vertical supports fit loosely in the slots of the base so I haven't glued them in place yet, they are just along for the ride right now. I then added and glued the first round of Vertical rings © but staggered them slightly so they do not align with the seam for the bottom pieces (A). Finally I added one Horizontal ring (D). Everything is being held using Harbor Freight Micro Spring Clamps.
That is where I am at currently. I have ordered some electronic hardware that I would like to include in this build and I cannot proceed any further until I mock up those parts. Right now I am planning on the orange light (of course) but I would like an option to include functional power supply or charger for my R2. I am still pondering this and have a ? on that part of the simple wiring diagram. If it doesn't work out, a prop cable to R2 will be fine with me. The generator will also have a removeable AC power cord, illuminated rocker switch for power, and a hidden fuse holder greeble.
Its going to be a hard for me to not have the ;jawa; icon on a forum so...
