Notes on Mr Baddeley's Plans
Lots of folks on the FB D-O Builder's Club are doing builds based on Mr. Baddeley's Plans, available on his Patreon.  There're also some Thingiverse plans, but those are more of a static model for now.
Anyhoo, Mat Prentis has some detailed info on his build based on Mr. Baddeley's Plans.
[Image: thumb_Adventures_of_building_a_D-O_rev-1.jpg]
Adventures of Building a D-O (rev 1)
Mat Prentis's Dio build info, detailed notes for Mat's build from Mr Baddeley's design.
[Image: thumb_D-O_OpenTx_program-_Mix.jpg]
D-O OpenTX Program & Mix
Mat Prentis's Transmitter Configuration and Code for Dio (D-O)
These are the same plans that Matt Denton used as the start for his build, though Matts made his own changes. (I can sympathize, I've never been able to leave well enough alone).
All of those resources should be enough to get most builders going!
