I started Treadwell prior to finding this website, so I created a build log for the droid at the RPF. So I thought I would post some of the highlights here.
Again more of a show off thread than a build log, but as I update things or add to the droid I will post it here.
I started off with the plans located at the Treadwell Builders Yahoo Group. I will post everything I have to the files section once I get a chance.
I started with some oak for the base and PVC for the body.
I built the neck with Sketchup and printed it with Shapeways. If you are interested in this same neck it is available at Shapeways or you can contact me for the file. It was my first attempt to make something like this, so it is rough. The neck needs additional work to get it to look right.
The head is made of Balsa wood.
Here is the finished droid.
Here are the various videos I made during the build.
Bot Builder
My YouTube Channel: https://www.youtube.com/@PaulsBots
