Kresty's Fusion Modified 3D Parts
I've updated my "modified 3D plans" - in V2 I now include all of the 3D parts as I touched most of them.
  • As before the top panels are symmetrical and have supports and alignment tabs
  • Lower hose mounts have slightly longer posts
  • Upper hose mount tee has mounting post for hose (print translucent)
  • Upper hose main mount designed to fit 7/16" OD hose in middle (print translucent)
  • Top coil mounts have small holes to affix coil ends
  • Top heatsink optionally split into two parts (to aid painting)
  • Included hooks that I used to attach the top to the bottom in my crazy split top.
As mentioned in the build thread, I had trouble figuring out how to attach the coils and hoses.  For the coils I placed small holes in the attachment parts to insert the coil ends.  For the hoses, the main mount is designed to shove the hose through and the upper T is designed to accept a transparent insert to attach the hose.
