Weird Wiki Logon Error
Wiki logon button may not always work.
Ok, whatever the problem is, it's "on me" since I did the stuff to make the wiki and the forum use the same logon, but just in case others see this:  I went directly to the wiki and apparently it was confused and didn't think I was logged in.  The wiki "logon" button took me to the wrong logon spot, so it didn't work.
If you have trouble logging into the wiki, just hit the rebeldroids banner, login there, then go back to the wiki, everything should be good.
