gnk-138 wip - Printable Version +- RebelDroids.net (http://www.rebeldroids.net/forum) +-- Forum: Droid Discussions (http://www.rebeldroids.net/forum/forumdisplay.php?fid=6) +--- Forum: Build logs (http://www.rebeldroids.net/forum/forumdisplay.php?fid=10) +--- Thread: gnk-138 wip (/showthread.php?tid=359) |
gnk-138 wip - grindhouse designs - 04-18-2017 here is the process in pics of gnk-138 this was the beginning right after the face plate, the body is just stacked at this point RE: gnk-138 wip - kresty - 04-18-2017 Well, you can tell where it's going for sure ![]() PS: In case it's "easier", there's an "images" link up top. Which has "my albums" you can create & upload to. Those images then have a bbcode thing in the info button you can copy the link to. Unfortunately both mechanisms can be a little bit annoying ![]() Anyway, thanks for sharing, looking forward to seeing your progress! RE: gnk-138 wip - deathproof - 04-21-2017 (04-18-2017, 06:40 PM)grindhouse designs Wrote: here is the process in pics of gnk-138 What's the best way to attach the two halves together? RE: gnk-138 wip - schubertrr - 04-26-2017 (04-21-2017, 07:55 PM)deathproof Wrote:I used rivets, also seen folks use sheet metal screws. I didn't want to glue them together, in case I wanted back in to do stuff.(04-18-2017, 06:40 PM)grindhouse designs Wrote: here is the process in pics of gnk-138 Sent from my SM-N900V using Tapatalk |
